Which side of the 8-Pin cable goes into the 4-Pin CPU connector?
Solved by mariushm,
Either side of the connector would work ... both parts are the same, 2 x 12v wires on one side, 2 x ground wires on the other side.
The connectors are keyed and IF the motherboard header is keyed as well, then one part of the connector would be the obvious one.
If the header is not keyed, then you can plug either part of the connector.
You'll have to excuse my crude ms paint skills :
(universal , can go in any header... I mean can go in any section of the EPS connector or the old P4 4 pin cpu power, or this 4 pin extra header ... not universal in the sense you could use with anything else, like video cards)
