Is my aio water cooler out used?
Xazur
My original pc build had a NZXT Kraken X60, from 2015 but in late 2020 I swapped it because it wasn't cooling anymore giving temps of 80c at idle. I swapped to a Corsair H100i that my brother had laying around from when he changed to a different aio water cooler, anyways just a few days ago I also started to reach 80c after I launched a game which triggered my aio fans to ramp up. I took my original aio cooler and examined it, titled it around and I hear water sloshing around. So I assume this is just the eventuality of aio coolers losing their water over time. So now I ask, should I keep getting a aio water cooler and encounter the same issue down the line yet again or switch to air cooling? I have a i7 5960x that I never overclocked, but I might if it gives me a few more years out of it.
Does it have enough of thermal paste? Is it dried out?
Not that active so I may not respond.
I mean, I literally installed the 'used' aio water cooler just half a year ago and I double checked the thermal paste adding on extra.
2015 was a long time ago..
AMD R7 5800X3D | Thermalright Phantom Spirit 120 EVO, 1x T30
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3060/1495 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
Tell me about it, I threw down $6K for my entire build then to 'future' proof. Turned out that doesn't work on tech.
Did you clean the original paste off first?  Because adding new paste onto old would only make things worse.
However I suspect you are right that the AIO have just aged, one reason I've stuck to air cooling.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Yes, I did remove the original paste from the aio and the cpu before applying new thermal paste.
Please tell me you didn't use a Kraken on a $6k build.  Custom loop at that price only, it would still be working fine today.
Mount the AIO upside down, it'll help keep any air from getting to the pump.
Grab another AIO, use it for 5 years and build another machine.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Is the pump fan connector an AIO connector or set to 100%?  I'm kind of curious if there's a fan curve issue of some kind, or air bubbles trapped in the pump.  Is the Corsair unit fairly old too?
I hear you buddy. I did that with X58.. used it for 9 years as my daily. I listed her for sale twice and I just couldn't keep it listed for more than ten hours lol.. she lives in a box on the shelf next to its older X48 brother now. I even took the battery out 😄
What kinds of sounds do you hear from the pump and rad? Feel any warm lines? you're sure its mounted with the proper hardware? I know its all basic stuff but sometimes things happen..
no such thing as tech future proof sadly
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
Current aio, corsair icue shows 58c as water temp, while cpu temp is 78c, this is not underload, all I am doing is streaming and running bluestacks.
