CPU won't go over 800Mhz
Solved by AMD A10-9600P,
I had this issue on an older AMD laptop last year before replacing it, and never got to fully fix it. On Intel though, there is more hope.
First try removing and reinstalling the graphics drivers for the Intel HD iGPU.
Check for any new chipset drivers.
Check if there is a new BIOS for your motherboard.
Clear the CMOS battery on the motherboard.
If that doesn't work, download ThrottleStop and click "PROCHOT", as sometimes a sensor can die and trick the CPU into thinking that it is constantly so hot that it needs to throttle down to 0.8GHz.
This is a bugger of an issue though, so I feel your pain.
