Mask Personal IP for Minecraft
Solved by PointFive,
6 minutes ago, Dujith said:Also its pretty cheap to rent a minecraft server these days, or any vps. But i do get even the cheap options like 5 Dollars per month can be alot.
Yea it is kinda cheap, but then again the only problem right now is the IP, aside from that I would think its better to just run it on my PC since it will be running better. But yea, thanks for the input.
Welp, it seems that there isnt any "easy" way to mask your IP, so I'm just gonna close the thread.
