Which cooler for R5 3600
ZeeDaynk
Which cooler would you recommend for a Ryzen 5 3600?
Trying to buy off Amazon, Here's the options I could find.
  1. The stock cooler (I heard it's quite loud)
  2. Deepcool GAMMAXX 400 V2 (Red Led)
  3. Deepcool GAMMAXX 400S
  4. Deepcool GAMMAXX 400 GTE V2
  5. Deepcool GAMMAXX C40
  6. CoolerMaster Hyper T4
  7. CoolerMaster Hyper 212 Black Edition
  8. CoolerMaster Hyper 212 EVO
  9. CoolerMaster Hyper 212 LED
  10. be quiet! Pure Rock 2
I'd go with the Hyper 212 or the Pure Rock, out of the choices. Hard pass on the stock cooler.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
Imo you should always try the stock cooler first before buying anything else. Maybe it's not too loud for your taste. It's perfectly fine to cool a 3600.
You can still easily switch your cooler without removing anything from your case.
If you think it's too loud, i'd recommend the Pure Rock 2.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
It mostly comes down to which fan the heatsink uses. From personal experience I would pick the Hyper 212 Black, alternativly the Pure Rock 2 for lowest noise possible. For a budget option, nothing can really compete with the Hyper 212 EVO, but try the stock cooler first.
