Mixing cas latencyes between dual channels.
Solved by Meridian Prime,
Okay so, I have a little experience with this from my iMac 5k, which I used for work and gaming. Mine came with the base 8 GB memory as well and I upgraded with a 16 gig kit for a total of 24 gigs of DDR3. As far as I know I did not check the base clock speed of the default ram, I simply added the new ram. I didn't run into any issues in the 6 years since I upgraded. Your experience may differ though.
