(Help Needed) RGB controller or Motherboard for the inwin 805i
So I got the urge to buy the 805 infinity case By inwin and it didn't come with the controller that it shipped with (got it off Kijiji for cheap) and my mother board doesn't have a RGB header so I was hoping that someone has found a good RGB controller that will let me customize the lights. I have a basic button controller that at least lets me run the lights but it would be nice to see what I could do with it.
If there isn't a usb 2.0 header could controller that will work, maybe a suggestion on a cheap new mb with a RGB header.
My build:
Motherboard: gigabyte AB350m-gaming 3
GPU: Nvidia GeForce GTX 1050
Cpu: AMD RYZEN 5 2600 six core, 3400 Mhz
Ram: 16 GB ddr4 at 2400 MHz
SSD/HD: nvme ssd m.2 254gb boot drive, 1tb SATA 2.5 hard drive
Fans/cpu cooler: cooler Master SF120x2, SF120r with a hyper 212 RGB black edition
And of course the case that made this post possible: inwin 805i
And yes I have it propped up with some 2x4 on both feet to help with the air flow problems. Clearly this is one of my lesser issues with the case as I've tried two different controllers with not luck. (Nzxt hue+ first gen, and the Razer RGB controller) I definitely want to fix my lighting problem as if I can't air flow will be the least of its problems.
so the SF120x2, is argb
SF120r is rgb
hyper 212 RGB black edition is rgb
inwin 805i  is rgb
Nzxt hue+ first gen, is argb
Razer RGB controller argb
so since your case is rgb i would replace the  SF120x2, fan with an rgb one.
so you would need an usb2.0 rgb controller and not an argb one. the problem is there not many options with software control.
heres a list of all the software controllers
Edited by thrasher_565
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
