Does ml360r fits gt301 case ?
Hudzell
hello guys my  r5 3600 cpu heating too much. like its always heating up to 105 degrees in 5 second at prime95 small ffts test.
So i have TUF B450-PLUS gaming motherboard and gt301 case, is ml360r suitable for my motherboard ?
can i sync the rgb lights ?
  • 3 weeks later...
Specs says 360mm rads are supported at front of the case.
Your mobo doesn't support ARGB, so you can't connect case nor AIO to it. You should be able to connect case ARGB to CoolerMaster controller or vice-versa. They should use standard connectors both ways.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
