PC no post and peripheral LED wont lit up
kevintong49521
The pc was built 10months ago and everything runs perfect. But today i found that the PC won't post and all peripheral LED also won't lit. I have tried running with only one RAM stick and switching ram slot. Also unplugged all peripheral device and led pins.
There were 2-3 times in weeks ago when the pc happened to be losing time setting after booting, but it ran back normal recently. Not sure if it is cmos battery failure and i haven't tested it yet.
Feel free to ask for any clarification, any input is appreciated, thanks!!
What has been observed:
1. No display, no post
2. All peripheral LED wont lit up (neither DRGB nor 12vRGB)
3. The pump and case fan spins at low RPM (usually it will spin at full speed for a while before getting back to normal speed)
4. Ram RGB does lit up
5. PSU fan also spins
Specifications:
B550i aorus pro ax
Ryzen9 3950x
Evga rtx2070s
Tridentz ddr4 8+8 rgb ram
Silverstone sx650-g
it seems like either motherboar or psu issue. likeyl motherbord issue since psu likely works (12V is working, 5V and 3.3V)
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
Update: i have shorted the cmos jumper and the computer works now.
But i am wondering what is the cause of the problem as I haven't modified the bios setting recently. So does the problem relate to a faulty cmos battery? Is it ok for me to short the jumper whenever i experience the same problem, or should I replace the cmos battery / warranty the board?
