RTX 3070 TUF Gaming noise
Solved by Mark Kaine,
1 hour ago, SavageNeo said:like buzzing? or whinng?
Then it is coil whine and you cannot really do anything about it.
Most of the time limiting the fps will help.
Theres 2 videos in the OP, I only listened to the 2nd, theres no buzz or whine, just a pretty damn loud fan noise (had to put volume to 160, otherwise it didnt sound like much, but phones etc are pretty bad at picking up noise so i imagine that being somewhat realistic)
Anyway, not much too hear other than fan noise, probably just bad airflow.
