Volume slider in windows 10 not adjusting volume with my headphones, have to control it manually on the headphones >:(
1 hour ago, Merlin_747 said:Every time I try to adjust it it's just not working. I have to adjust the volume on my headphones. I have no clue why is this happening, I tried various methods of fixing it and nothing works so far. I tried controlling the volume with other headphones (jbl e45bt) and it's working. Why is that? Is it a headphone issue, and why? Don't get confused the slider opens and slides I just can't control the volume. I'm using bluetooth headphones jbl tune500bt. Also sometimes the audio just starts crackeling until I restart the system... Also the system recognises the hands free ag audio of the headphones as a mic which it isn't. Idk if that's a problem tho. I can control the volume on my phone and everything so it must be a windows issue? Idk what else to say I didn't mess around with windows settings much so I hope it isn't me.. I appreciate any help, thanks guys.
Anyway found the solution...
I described a problem on a get help windows app and there I found the solution.. So the solution is to type a following command in cmd(ofc run as an administrator): "reg add HKLM\SYSTEM\ControlSet001\Control\Bluetooth\Audio\AVRCP\CT /v DisableAbsoluteVolume /t REG_DWORD /d 1 /f" and then restart the pc. This solved my problem for now. Thx for helping me anyway.
