What's the max safe temp for a 10400F?
Solved by FavoringWinter,
33 minutes ago, Pixelfie said:My 10400F gets ~50c when gaming and the cooler makes a lot of noise, so I'm trying to change the fan curve. What would be considered the max temp?
You should be able to change the fan curve in the bios. You can adjust it from their to fit your liking on noise to performance. I would go for it to be around 65c while gaming, but it is completely up to you
