Looking for a gaming laptop in the average price range ($1000-$1300)
Hello!
I'm new here, and I came to ask some questions. I am currently looking for a new laptop. I have been wondering, which brand should i choose, but also which model. Im aiming at a gaming laptop within a price range of $1000 - $1300, so a bit above average. I like asus laptops, so if you have some reccomendations it would be nice, if you shared some models.
I also want to know, would an RTX gpu be an overkill for me, or should a GTX 1660 Ti be fine, as I don't play AAA games - my current laptop is 7 years old (a dell inspiron 5537) and i mostly play minecraft - the only game it can handle. However, I want to get my hands on the good PC games I missed having a bad laptop.
Any recomendations? Your gaming laptop experiences? Please share your thoughts on my questions and possilby answer them.
PS: Is the TUF Dash F15 FX516 good? It has nice specs and is in my price range.
1660 Ti or upcoming RTX 3050 Ti should be good. Check Lenovo Legion 5 with 1660 Ti, 4800H or 10750H and 144Hz screen (the 120Hz is "base" and has worse spec). HP Omen with similar specs also take good reviews. Ryzen 5800H + RTX 3060 newer options are also worth checking.
It has a quad core semi-low-power Intel CPU which may be a problem, but if it has RTX 3060 then the GPU side will be better. If it has RTX 3070 then it's a meme - as the GPU has super low TDP set and isn't performing anywhere 3070 would while already being limited by the CPU in most benchmarks.
Its the one with the RTX 3060, but i dont mind the quad core CPU as I currently only have a dual core one
A wogóle to siema
If you start playing more modern games you may end up being CPU limited - like Cyberpunk and friends. It has a relatively good price but there is a catch to it - you would buy a new laptop that is already "old" and will age badly. 6-8 cores is the norm nowadays.
And in which country do you want to buy it ? 🙂
In Poland, as I live there.
Edit: If the Dash F15 is this bad, then should i look in the ROG series instead of the TUF series? And also look for a AMD cpu laptop?
No to jedziemy:
Okazje można szukać w outlecie X-komu i Morele:
https://allegro.pl/uzytkownik/X-KOM_PL/laptopy-491?bmatch=cl-e2101-d3794-c3683-ele-1-1-0429&order=d&liczba-rdzeni-procesora=6&liczba-rdzeni-procesora=8&model-karty-graficznej=NVIDIA GeForce RTX 2060&model-karty-graficznej=NVIDIA GeForce RTX 2070&model-karty-graficznej=NVIDIA GeForce RTX 2080&model-karty-graficznej=NVIDIA GeForce RTX 3060&price_to=5000
* https://www.morele.net/outlet/
Jeżeli dają normalną gwarancje, nie rozwalony albo nachalnie używany to może być dobra opcja. Np:
https://www.morele.net/laptop-msi-gf75-thin-10uek-039xpl-5945986/?sekcja=outlet - drobna ryska na matrycy (warto sprawdzić zdjęcia)
Z nówek dobre minimum to Lenovo Legion 5 z 1660 Ti:
* https://www.x-kom.pl/p/650485-notebook-laptop-156-lenovo-legion-5-15-ryzen-7-16gb-512-gtx1660ti-120hz.html
Mogą też być wersja z 10750H i nieco droższe z 144Hz ekranem więc możesz sprawdzić inne sklepy. Ogólnie 6+ rdzeni (Ryzen 4000 lub 5000, Intel 10 000 lub wyżej, ew 9000) i 1660 Ti jako podstawa. 2060 niewiele lepiej chyba że cena ta sama. 3060/2070 zdecydowanie lepiej - tyle że CPU musi być dobre. Plus sprawdź recenzje na notebookcheck konkretnego modelu by sprawdzić czy nie spartaczyli chłodzenia lub podobnie. Możesz też trafić na MSI/Dell z dGPU AMD - to zazwyczaj jest w okoli 1660Ti więc ~4000 PLN lub niżej.
1 minute ago, riklaunim said:
No to jedziemy:
Szukam laptopa tak do 5 koła, więc powiedz czy seria ROG asus jest dobra, bo Lenovo Legion 5 pytałem się eksperta i mi mówił że jest strasznie głośny i się będzie grzał, a poza tym to mi się nie podoba
Lenovo Legion jest dobry lub zły w zależności od serii. Legion 5 jest dobry i się nie grzeje ale Legion 7 już jest meh/poniżej oczekiwań, plus wcześniejsze 5 też były meh.
Asus to zależy która seria. Warto wrzucić ją w notebookcheck.
ok, dzięki, poszukam w necie. Czyli mówisz że jak w tej cenie to poszukać raczej z prockiem AMD a nie Intela? I co myślisz o seriach ROG strix albo zepherus?
Intel dobry o ile ma 6-8 rdzeni. AMD dobre o ile to seria 5000 lub 4000 przy odpowiedniej cenie.
Zephyrus całkiem fajny a Strix to jakby półka wyżej niż TUF - powinny być dobre tyle że droższe. Wszystko zależy od modelu.
ok, dzięki jeszcze raz za pomoc!
things just went from english to polish real quick but the omen 15z en100 has an 80w 3060 with a 5600h for ~$1100
