Need help with 3x gpu, TR4 build
By
LNW
in Troubleshooting
in Troubleshooting
Solved by Moonzy,
use risers on 2 cards?
they'll be flopping around, but at least they can function
though if you do, either get pcie 4.0 riser or manually set pcie gen to lower version
Or put a card in slot 2 and slot 4, assuming slot 4 fits larger than 2 slot cards
Then use riser on top slot
ViciousRaptor ·
Posted in Troubleshooting7 -
KennethC90 ·
Posted in Cases and Mods0 -
ComputerOuchies ·
Posted in Troubleshooting0 -
EzioWar ·
Posted in CPUs, Motherboards, and Memory5 -
AdityaSaraf ·
Posted in Displays2 -
gooseta ·
Posted in Troubleshooting5 -
Dareios-Gintoki ·
Posted in Troubleshooting8 -
1
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
