LiPo battery charging rate with desk bench power supply?
Solved by MadAnt250,
1 hour ago, babadoctor said:Other people suggest charging it lower.
Stackexchange says charge it at 1/10th, so, 520 milliamps at 12.6v? I'm so confused..
Wait one sec. You want to use a bench power supply too charge a LiPo battery?
Unless your device can charge in a specific way, this can be dangerous.
https://www.electronics-lab.com/using-bench-power-supply-charge-lithium-ion-batteries/
Check out EEVbog's video.
The information I told you is for charging LiPos with chargers specifically designed for charging them, because all you pretty much have to do is punch in the numbers and let the charger do it's thing.
