Constant crackling and popping noises from Razer Nari headset
Solved by xniqht,
On 5/8/2021 at 7:02 AM, Tigerleon said:It sucks I know. You spent 170 on garbage headphones. Razer is not a company you want audio gear from. End of story. I don't really know exactly what causes the popping and crackling. When did you buy them? Can you get a return?
Plugged it into USB 3. Issue solved. Not garbage lmao, just unclear instructions, fire headset.
