3600Mhz RAM kit running at 3200Mhz, can DRAM Calculator for Ryzen optimize it ?
Solved by Levent,
Depends on the chips used on it. If you wanted to use 3200mhz, you would select 3200mhz in the drop down menu.
chrisjojo ·
Posted in Troubleshooting1 -
Rikothegamer ·
Posted in PC Gaming3 -
4
2
1
1
2
2
Meaker ·
Posted in Graphics Cards3
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
