Search In
  • More options...
Find results that contain...
Find results in...
I have 2 monitors that I want to be displayed off my laptop. I want to put discord on a vertical one and Minecraft on the big one. When I set up the big one and then plug in the vertical one they both mirror the same image. (Keep in mind for the big one I did display on 2)
I started with the laptop and vertical monitor as seperate windows. Then I wanted to put the laptop screen on the big one but the big and vert one are now displaying the same thing
And I want them to display separately
In the options for multiple monitor setup, you want to extend the display, that will give you a desktop that spans both monitors, allowing you to drag apps/ windows onto the vertical display.
Yes this, also you can hit identify in order to see the assigned numbers of each monitor and reposition them in windows as necessary for your setup.
In Windows 10, go to your desktop, right click -> select display settings -> scroll down till the end -> under multiple displays, select "Extend these displays" from the drop down
When I hit extend the laptop screen lights up and I have that screen and the 2 monitors mirroring a different screen
But I wanted the big monitor and the vert monitor to mirror different windows and the laptop to have none
Either close the lid on your laptop or using the function keys, look for the icon with the monitor logo and select "Second screen only"
When I close the laptop they both shut off
Ok so I shut off the laptop but I have these 2 displaying the same thing how do I make them display different windows
Select the extend displays in the settings I mentioned earlier.
I did and it did this
^ @synthaxe404it needs to be on the big monitor and vert monitor. It’s ok if u can’t help I understand
Go back to your display settings and on the very top part you will see Rearrange your displays, under that you have a button that says  "Identify" click on that and look at all your displays and you should see a number. Select the number of the display you want to be your main display on the big box in the display settings and then scroll back down, under the multiple displays option again there should be check box with a label saying "Make this my main display", tick that.
