Are Noctua NF-P12 redux-1700 PWM zero RPM mode fans?
Mark Kaine
I need replacement fans for my bottom intake to cool my GPU (3070) i currently have some Lepa fans installed which are ok, but their min speed is 600RPM, so I want to make sure the replacement fans can actually turn off completely when the GPU is not in use, i found the info for some other Noctuas (they do *not* turn off completely) but i cant find the info for the redux ones...
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
If you want the fans to turn off, you need to specify that in BIOS. Fans respond to the voltage/PWM signals they're given, and don't have any "smarts" to enter zero-RPM mode without being told.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Mellanox ConnectX-3 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X540-T2 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / Seagate 1.5TB HDD | Corsair CX450M | Hauppauge ImpactVCB-PCIe | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
As far as I'm concerned, the "zero db" features is upto the motherboard bios or what ever fan controller you plug the fan in like Corsair icue
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
eh, not really, some fans have specified minimum RPM, such as the Lepa (600 minimum) or the other Noctua(1400 minimum!)... the problem is the info is sometimes not given , i guess i have to dig some more then, as i couldn't find the info for this specific fan yet.
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
I found something
362230937_Screenshot_20210505-153552_SamsungInternetBeta.thumb.jpg.bce657fccdb2faa0a3bdfaaa6f4da6a8.jpg
still not really conclusive... looks like the 900 arent pwm and the 1700 indeed have *minimum RPM*  of 450, oof.
Edit:  i guess i get what you're saying , but my current PWM fans will *not* ever turn off, theyll be 600rpm minimum...
i do know silent wings 2 (3pin) do turn off completely on the same fan header, so i either need to buy those (apparently my exact model isnt available anymore tho) or i have to swap some fans, and hope it works.
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
The minimum rpm refers to the lowest rpm the fan can run at. Below the minimum rpm, the fan stops spinning.
Depending on your motherboard, there may be a setting to enable fan stop. Some motherboards don't allow for very low fan speeds.
Right, i got confused with this , so what i think i really need to do is buy two 3pin fans, because im like 99% sure i tried that before and those actually stopped spinning on that header.
i mean thats the thing, it works on any header with pwm or dc fans, except that one header only stops dc fans - if i remember correctlly.
i guess i should really try swapping the 3pin fans with the 4pin vans to be sure .
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
3pin fans often have a higher minimum rpm since the the speed is lowered by lowering voltage. PWM uses 12v pulses which can keep the fan running at lower speeds.
Keep in mind that not using enough power to get the fan spinning can still heat the motor up. This can wear the fan out more quickly if not properly cooled. The fan usually cools itself when in operation.
But, what im supposed to do then? i have pwm fans (the Lepa) as the bottom intakes currently and they simply wont stop spinning, minimum always 600rpm.
So basically just take the risk with 3 pin fans of the fans wearing out faster?
I mean right now ive decided to simply not buy any new fans, but long term i need a better solution, while everything works at the moment this setup isnt ideal , for example i also need another fan for the "pull" on my cpu cooler , its currently not even connected to the cpu fan header because it just spins at full blast when i connect it (also a pure wings 3pin) and the bequiets *are* loud when run at full speed lol.
(just to show how it currently is, at idle)
Tldr, i believe only 3pin fans will work properly on the bottom intake, and ill also need a solution for the second cpu fan (probably pwm) , its a mess , and i think its because of the motherboard controls not really working as they should (msi b350m mortar)
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Do the fans stop if you manually set the fan to 0%?
3pin fans run at 100% rpm when using pwm since it doesn't have the 4th pin and pwm ic to modulate the incoming 12v signal. Use dc / voltage control instead for 3pin fans.
yeap i understand the issue of the cpu fan, it's because the header is pwm only, so the noctua fan (push) works properly but the bequiet 3pin will run at 100%.  i managed to put that on another header and its spinning roughly at the same speed than the noctua.
Funny thing is i can set the cpu header to dc, which will make both fans stop spinning (when connected to the cpu header) lol ... I don't think thats supposed to happen , but happens  regardless. It just makes me think something is dodgy with this motherboard.
The bottom intakes are pwm and the header is set to pwm, and no, they do not stop spinning if i set them to 0, they are always running at 600pm minimum, which is what i dont understand.
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
What fan curve are you using with the dc setting? As mentioned, the minimum rpm is generally higher with dc.
Check and see if there's a setting that disables fan stop. If there isn't, it may be that the fan doesn't support 0% rpm with pwm. You can try dc instead or software like SpeedFan or Argus Monitor for 0rpm with pwm.
Thats something i wanted to try, because if that would let me control the bottom fans i wouldn't need to buy any obviously . Problem is i tried speedfan, didn't seem to work at all on my board (msi b350m mortar).so only Argus left....
Otherwise after some thinking , ill just need 1 3pin pure wings 2 , because i have one spare, so i can try those in the bottom and hopefully they'll work ,and i leave the cpu fans as is , its not ideal (because push pull is on 2 different headers) but its working pretty well otherwise.
And sorry for not answering your orher questions, im a bit confused which fans your asking about now, but any fans i have installed can go 0 rpm, except the 2 on the bottom  - which i think is because they are pwm, i know for sure i had *one* 3pin fan there and that stopped spinning when not under load no problem, so it shouldn't be a problem with two 3pin fans either?
And ill try Argus first though !
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
3pin fans should be fine. The Lepa fans probably aren't stopping with how the pwm is implemented.
