5900x ideal max temp?
Slamscape
This is my first time building my system from scratch. And I am wondering if 73c while at 4500 clock and 100% usage would be considered a good temp for a 5900x on a crosshair dark hero MB.
I have an ek 570 mono block on it, as well as the ek vector for the 3090FE.
the loop has a top 360mm set to exhaust, and a front 420mm pulling air in.
hottest water hits the exhaust rad first.
So far for gaming I’m seeing it cap out in the 60s. And the only thing so far to put it in the 70s is the acronis true image backing up my drive.
once the clock drops out of the 4500 and into 3600 for a few moments the temp instantly drops into the 50s until the clock speed goes back up.
Normal idle temp is 33 cpu and 28 gpu
I would say its fantastic. I am playing CoD MW and I am at 69C with 74C max temp on a 240mm AIO so I would say you're doing good.
Edit: System has 5900X and Corsair 240mm AIO.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
it's good enough. it doesn't have to be amazing just has to be under 80 ish to be comfy
I like amazing though. 😛
ok neat but the cpu doesn;t care regardless
It’s good! I have an ek velocity with 2 360’s the EK very thick and medium rads and an EK distro block +pump for the OD-11 XL and mine jumps immediately to 75+ With any sort of load. Any gaming or transcoding and it’s above 80 within 5 mins and climbs a bit from there
I suspect it’s the cpu block as my old 3950 ran unreasonably hot also
My personal Max temp is around 75c. Though I try to keep it under 70c as much as possible.
Quiet
Cool
Powerful
You can only choose two
i5 8600 - RX580 - Fractal Nano S - 1080p 144Hz
3 hours ago, NineEyeRon said:
Quiet
Cool
Powerful
6 static pressure and one air flow fractal Venturi fans plus the ek pump.
quiet it is not.
which is why I was looking to see if I was getting a desirable cooling for that price.
-> Moved to Cooling
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
