keyboard mod Searching for reassurance on how replacement switches work
Solved by seon123,
19 minutes ago, LisaMiza said:How do I know if they pins line up to the pcb?
They are standardised. As long as you get Cherry MX style switches you'll be fine. Whether they be from TTC, Durock, Gateron, Outemu, Cherry etc etc. If you get 5 pin switches, you'll just have to snip off the two extra plastic mounting legs, which can be done very easily, e.g. with side cutters.
20 minutes ago, LisaMiza said:And what keys are more quite than the ones I already got, and will match the holes in the pcb?
If you want silenced switches, there are quite a lot of options. Are you looking for tactiles or linears?
If you want to avoid having to desolder the old switches and solder on new ones, you could consider QMX silencing clips instead. Just don't get o-rings.
