My EASIEST PC Build In Years! - Louqe Raw S1 Build
jakkuh_t
He already managed to drop something 43 seconds in
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
I haven't watched the video yet, but I'd personally recommend against going with this case. L12S + 3 slot GPU in vertical form should be at most ~10L including "stand" to route cables under the case. The SSUPD Meshlicious is only 2L more yet it supports a 280mm rad and has much better ventilation.  This case is definitely not worth $329 imo
Current System: Ryzen 7 3700X, Noctua NH L12 Ghost S1 Edition, 32GB DDR4 @ 3200MHz, MAG B550i Gaming Edge, 1TB WD SN550 NVME, SF750, RTX 3080 Founders Edition, Louqe Ghost S1
The Meshlicious is $130, if you want a more budget SFF case, that'd be my recommendation.
Ventilation is a bit anemic. What's the thermal throttle threshold for a RTX 3080 TUF?
When I see a product I like:
When I see the price:
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
This is definitely a contender for my next living room rig (I'm currently using a standard ATX workstation build but once that get moved to another room I'll need something else to power VR and TV gaming).
The Potato Box:
AMD 5950X
EVGA K|NGP|N 3090
128GB 3600 CL16 RAM
The Scrapyard Warrior:
AMD 3950x
EVGA FTW3 2080Ti
64GB 3200 CL16 RAM
Is there supposed to be a comma at "5,900X" at 5:04 in the subtitles(CC)?
edit: Looked this age question hurt: (7:41)
Edited by MultiGamerClub
Useful threads: PSU Tier List | Motherboard Tier List | Graphics Card Cooling Tier List ❤️
Baby: MPG X570 GAMING PLUS | AMD Ryzen 9 5900x /w PBO | Corsair H150i Pro RGB | ASRock RX 7900 XTX Phantom Gaming OC (3020Mhz & 2650Memory) | Corsair Vengeance RGB PRO 32GB DDR4 (4x8GB) 3600 MHz | Corsair RM1000x |  WD_BLACK SN850 | WD_BLACK SN750 | Samsung EVO 850 | Kingston A400 |  PNY CS900 | Lian Li O11 Dynamic White | Display(s): Samsung Oddesy G7, ASUS TUF GAMING VG27AQZ 27" & MSI G274F
I also drive a volvo as one does being norwegian haha, a volvo v70 d3 from 2016.
Reliability was a key thing and its my second car, working pretty well for its 6 years age xD
It's a Ghost S1 flipped on its back. At least it looks better than the Ghost.
  • 1 month later...
Did anybody tried this case with RTX 3090 FE? I have it currently in Define 7 Compact and I am thinking about switching to ITX. I must say that Louqe Raw S1 is amazing but I am worried about temps.
  • 4 weeks later...
Im in love with this case. I wanna build a pc around with it, along with RTX3060. Any suggestions or ideas?
Specs in mind:
Ram; 16GB should be sufficient, no RGB required.
Storage; SSD 500GB+/-, HDD 2TB+/-     ? Hows it sound?
CPU; something good enough that doesnt bottleneck, no need to be overpowered. I dont mind running games on just PC mode, 2k? 4k? no need tq.
PSU; no idea with models, need suggestion on this.
