My daily driver exceeds LTT “Our Craziest Cooling Project Yet”
NeoXanthus
I watched the LTT video label “Our Craziest Cooling Project Yet”
and realized if that radiator is crazy my daily driver must be completely insane.  I run a custom water-cooling solution with 18 fans 9 push and 9 pull with 2 pumps also in a push / pull configuration and about 3.9L of fluid in the system.  This is to cool a 3990x CPU dual 3090’s and dual titan XP’s.
Outside of the radiator
Variable power supply for the 18 DC fans for the radiator
Outside of the computer uses 120v AC fans.
Inside of computer all EK blocks.
Custom water-cooling fluid.
Might need to revisit cable management sometime.
Power supply required for 4 video cards and 64 core CPU, this plugs into a 30 amp L6-30 twist lock.
Here are some stats from the computer.
Here are the temps.
This is my daily computer both for work and gaming.  Before any gets upset about power usage I have a 15.04KW solar system on my roof.
Can't decide if I love it or hate it. Absolute madman, that's for sure.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
3 minutes ago, NeoXanthus said:
I miss seeing these absolutely wild builds.
Radiator looks like the MO-RA3 360 LC? I've a 420 LC on my shelf and currently daily a 420 Pro.
Your coolant is probably part-antifreeze right?
The coolant is "Distilled water 75% of volume / Prestone low-tox propylene glycol (Corrosion Inhibitor) 24% of volume / ethylene dichloride (algaecide) 0.5% of volume / iodine (bactericide and fungicide) 0.5% of volume."
Considering how terrible it was, I'd say you'd win by default anyway.
That said, very cool. 👌
Moved to Build Logs
F@H
GPD Win 2
33 minutes ago, NeoXanthus said:
Here are the temps.
Were those temps taken during idle or full load?
If it's the latter, then damn dude, that's chill.
Under full load like using a cuda app it will not exceed 45c but usually stays around 42c.
That's really cool. Good job!
