When changing resolution, Apex vsync caps at 60fps
Solved by Sauron,
Try setting your monitor to that resolution and 75hz, then open the game - when you change resolution ingame it tries to set your desktop to that resolution but it may not set it at the correct refresh rate.
220VoltsallCore 路
Posted in Displays7 -
1
xo33 路
Posted in New Builds and Planning4 -
2
Linkinworm 路
Mortal_2077 路
Posted in Graphics Cards1 -
10
2
5
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
