How is silence transmitted over radio
25 minutes ago, Moonzy said:it's actually a great question
since there's a constant static noise as background, how can radio transmit silence, which excludes the static background?
All it means is there is no modulation of the signal (Audio being carried by it) so you hear nothing. When you come across a blank station it's just an indication a signal on that frequency is being picked up.
The signal itself is just that and no more, it must have modulation of some kind for it to carry audio that you'd hear, the modulation being from the audio content it's supposed to be providing.
Think of modulation as the vibrations of a guitar string and the signal itself as the means/medium of providing the vibration to your radio so in turn, it can translate it through your speakers for you to hear where you are.
