unconsistent FPS charts on an old system
2 minutes ago, NotBoraAtAll said:I see, so what do you think I should do then? Do I have to change the CPU out for a new one like the 5600x maybe? If I do that, I would also change the GPU too. Or is there anything I can do like changing some settings?
You could try and see if you can get cheap used CPU. The mobo is compatible with 6th and 7th gen CPUs from Intel. So up to 7700K (which would require aftermarket cooler too). Overclocking is not possible, but I think just having i7 would help here.
For GPU, as you might already know, upgrade is not feasible really. Anything with capable power is hard to get. I don't think going for GTX1660 is worth it here. So changing thermal paste on it might be just best for now. Get those temps down, under 85C, to prevent throttling.
