well trying to think between sdd or m.2 ones
Solved by SorryBella,
6 minutes ago, ShiroEerie said:well just thinking of buying the 240-500gb ones either ssd or m.2. but some say m.2 overheats too much and it is much better to get a ssd well can i have others opinions about this
Youre confusing the m.2 INTERFACE, and m.2 NvME PROTOCOL.
If both runs at the same protocol (NVME or SATA), both will run as hot as the other. The advantage of the 2.5 inch SSD is that they have more surface to dissipate heat but thats moot point because the heat generating chip is confined inside of a closed enclosure. and as long as you dont put on a bad m.2 "heatsink" shields, the temperature should be under control.
