Creality Ender 3 Pro vs Ender 3 v2
The ender Pro is generally better in terms of software. due it using marlin as its firmware, which has a good community backing it. allowing you to easily flash the firmware and add features to it.
Not forgetting both printers have a 2020/2040 frame allows you to upgrade quite a lot of the printer.
it just depends on how much you want to do with the printer.
the V2 already has a few upgrades i would personally recommend like a glass bed, and belt Tighteners
which would cost you about the same as if you would buy it separately. {aliexpress prices}
in my opinion, i would suggest to go for the V2 if you are a N00B with 3d printing.
and go with the Ender Pro if you want to upgrade/hack your entire machine down the road, adding extra features to it, like the hardware features the V2 already has.
