Can I connect 3 fans to my old motherboard ?
Solved by FRD,
1 minute ago, Latvian Video said:The fans and the hub he linked are PWM
Looked it over a bit quickly, that's right.
The Arctic fans are actually really good budget fans. The 5 pack normally is about $25 and they really do what you expect from fans.
Some notes though, they're best used in push configuration, not pull. Also on max speed they can be louder than other fans, but they're budget ones anyway. Finally the cables are good length, but not superlong like on the more expensive fans. It should be fine with a hub though, you just need to place it in a good spot.
