125+ watt am2+ cooler
da na
Does anyone know a good AM2+ cooler for Phenom IIx4 955? I would prefer one that attaches via the clips because I'm using an eATX motherboard in a micro atx case, so the backplate doesn't fit in the motherboard tray so I have to take the board out to access the screws. Budget of $50 but can go over if there's a really nice one, and no liquid cooling, lol
Thanks!
Pretty sure those clips fit the Wraith prism, considering the Ryzen 9 3900X (albeit not extraordinarily well) is cooled by it
Primary PC:
I know the Cooler Master Hyper TX3 uses the clip system for AMx sockets, but I dont know if its available for purchase anymore.
I used it for a ryzen 7 1700X while I waited for the AM4 bracket for my AIO, and it did just fine
If you want me to answer, please use the quote function or tag me. I dont get notified unless you do
What case and ram are you using?
Where are you shopping / located?
10 hours ago, wat3rmelon_man2 said:
Newegg, Amazon, ebay, in the US, using some low profile ram and a Rosewill SRM-01b case.
PR Slim is good: https://pcpartpicker.com/product/hyQRsY/be-quiet-pure-rock-slim-351-cfm-cpu-cooler-bk008
