Hi , is normal on a corner of motherboard look like missing a bit of paint or look more like silver colour not black.
Solved by trag1c,
Solder mask is the term you are looking for.
https://en.wikipedia.org/wiki/Solder_mask
You will be fine.
SOROBIN ·
Posted in Graphics Cards2 -
OldFord76 ·
Posted in Troubleshooting0 -
Blawe17 ·
Posted in Troubleshooting2 -
Ronbaow ·
Posted in Troubleshooting1 -
zoneeye ·
Posted in Troubleshooting5 -
leclod ·
Posted in Operating Systems3 -
PatRed ·
Posted in New Builds and Planning6 -
3
2
StormBreakes ·
Posted in Build Logs1
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
