Search In
  • More options...
Find results that contain...
Find results in...
Which keyboard and key switches
I was looking for a good 60% or 65% has to have rgb (a volume wheel would be nice) switches like cherry mc reds but quieter if possible if not is okay) would the rog The asus falchion be good
You want a reduced sized keyboard but with a wheel that increases size?   That might be a rare bird.  Or not.
The Glorious GMMK Pro is a choice, though you'd have to buy the switches and key caps separately and assemble it yourself. It matches all your requests otherwise.
GMMK Pro is a 75% board - still a solid choice.  I would also recommend the NovelKeys_ NK65 (Entry or Non Entry - Entry is a polycarb case which can be somewhat better for RGB lighting).  With either you'll have to source your own switches, which I would recommend taking a look at Gateron Yellows - good bang for the buck - and another great choice would be a set of Everglide Aqua Kings (63g or 67g) should be good.  Anything else I know that would have a rotary knob are made in GB and you would need to be handy w/ soldering (if you are, then you're a step ahead of most coming into this hobby).
Project Gray Scale
Intel Core i7 6900k @ 4.2Ghz - Dominator 32GB DDR4 2400 CL10 - Samsung 970 EVO+ 1TB NVMe - 2 Samsung 840 EVO 1TB (Gaming and Sratch) - 2 Barracuda 2TB
Asus x99 Deluxe - MSI Aero OC GTX 1080Ti - Seasonic 760 XP² - Mod1PC Custom Cables - EKWB CPU & GPU Blocks Nickle/Plexi - EKWB D5 PWM
EKWB PE360 - Corsair ML120 (6)  - InWin 303- NK65 Entry Watermelon w/ Gat Laseron 70g (205g0 & Filmed) - Glorious Model O
Kanto YU2 - Sennheiser PC360 SE - Acer XF270HU
BUT DOES IT FOLD?! https://folding.extremeoverclocking.com/user_summary.php?s=&u=963814
