USB ports going crazy with VR set
Solved by BenEspin05,
4 hours ago, Flannelist said:This sounds like you're exceeding the amount of power available to all USB ports. I would try with less sensors, or more sensors plugged into individual ports if possible. If not, I would look into a USB PCIe card as that will have its own controller, so it wouldn't be reliant on the one on the board.
I hadn’t thought about an expansion slot specifically for my VR. This is great I’m going to try this and follow up on here it delivers tomorrow. Thank you so much for this idea.
