Search In
  • More options...
Find results that contain...
Find results in...
Spotify's bitrate quality when streaming to "another device"
Go to solution Solved by AbydosOne,
44 minutes ago, DSD27 said:
If I control everything in Opera (web), but I make it so it reproduces in the desktop client, will the bitrate quality be the one from the web app or the desktop client?
AFAIK, the control-over-the-network feature in Spotify just tells the target device what to play, and the target device does so with all its settings. It's not streaming from the controller.
I'm using the built in music player of Opera GX, which has Spotify. Sadly, Spotify on the web tops at 256kbps, but in the desktop client it can do 320kbps.
Ryzen 5 2600X / ASRock Fatal1ty B450 Gaming K4 / G.Skill RIPJAWS V 16GB (2X8) 3000Mhz CL15 / Gigabyte RTX 2060 Super Gaming 8GB OC / Corsair RM650X 2018 / Crucial BX500 240GB / Western Digital Blue 1TB 7200RPM Cooler Master MasterBox E500L /  ASUS TUF Gaming VG27WQ // Rog Orion / Corsair Harpoon RGB Pro / Cooler Master MasterKeys Lite L / Xbox One Red Sport  Special Edition Controller for Windows
Main System (Byarlant): Ryzen 5 1600X | Asus B350-F Strix | Corsair H80i V2 | 16GB G.Skill DDR4 3200MHz CAS-14 | XFX RX 5600 XT THICC II | Samsung 960 PRO 512GB / Samsung 970 EVO 500GB / Seagate 7200RPM 3TB | Corsair CX650M | Mellanox ConnectX-2 10G NIC | Anidees AI-07BW Case | Dell U3415W Monitor | Microsoft Modern Keyboard
FreeNAS Server (Veda): Core i3-4170 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 4x 10TB WD Whites / 1x Samsung PM961 128GB SSD / 1x Kingston 16GB SSD | Corsair CX430M | Mellanox ConnectX-2 10G NIC | LSI 9207-8i LBA | Fractal Design Node 804 Case (side panels swapped to show off drives)
Media Center/Video Capture (Jesta): Core i7-2600 | Asus H77M-PRO | Stock Cooler | 8GB No-name DDR3 | EVGA GTX750Ti SC | Sandisk UltraII SSD 64GB / Seagate 1.5TB HDD | Corsair CX450M | Hauppauge ImpactVCB-PCIe | Syba USB3.1 Gen 2 Card | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | UMIS 256GB NVMe SSD | (all-around awesome machine)
Laptop (Rozen-ZuluSony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Kingston 120GB SSD | Blu-ray Drive | (lived a good life, retired with honor)
Tablet (---): Samsung Galaxy Tab A 8" (crosses fingers)
Tablet (ReGZ)Asus T102HA (BIOS clock doesn't tick, loses time when sleep/off) (I kill tablets with disturbing regularity)
Tablet (Unicorn)Surface Pro 2 (battery will reset total capacity to current charge, leading Windows to think it's always 100% charged until it dies)
Tablet (Loto)Dell Venue 8 Pro (screen discoloration issues, wouldn't update to Windows 10)
Tablet: iPad 2 16GB (WiFi died, basically useless after that)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M (?) | HooToo USB 3.0 PCIe Card | NZXT H230 Case
Camera: Sony ɑ7II (w/ Meike Grip) | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance SDXC cards
Then I can control it in the web and it will output 320kbps through the desktop client... Nice.
Edit: But for this specific case, never mind. It can be done, but if you do it, the functionality of Opera GX which automatically stops the music when you start watching a video or media and then resumes as soon as you finish, won't work.
@AbydosOneDo you know if when we're listening on the web (without the desktop), our followers can see what we're listening to?
I would assume so (it's all one unified platform), but I don't know for sure because I turned all that off.
But the settings for that are not present in the web, only in the desktop client and maybe mobile. that's why I'm curious.
