Should I sacrifice screen resolution for better CPU and performance?
Solved by aisle9,
1366x768 displays are cancer. For one, they're totally unacceptable in 2021. Two, they're all low-quality TN panels with crappy viewing angles and terrible color. IIRC, the 3500U and 4500U use the same Vega 8 graphics. You're not losing much performance at all in terms of GPU performance.
2
Anonymous Reviews ·
Posted in Member Reviews1 -
SOROBIN ·
Posted in Graphics Cards7 -
OldFord76 ·
Posted in Troubleshooting1
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
