hay this is my first time building a PC so I need help finding if these parts are compatible with each other
Budget (including currency): about 6K USdollar
Country: USA
Games, programs or workloads that it will be used for: Games
Other details:[CPU]   Amazon.com: AMD Ryzen 9 5900X 12-core, 24-Thread Unlocked Desktop Processor: Computers & Accessories   |   [GPU]   ASUS GeForce RTX 3090 24GB GDDR6X PCI Express 4.0 Strix Graphics Card Black ROG-STRIX-RTX3090-O24G-GAMING - Best Buy   |   [RAM]Amazon.com: Corsair Vengeance RGB Pro 32GB (2x16GB) DDR4 3200 (PC4-25600) C16 Desktop Memory – Black: Computers & Accessories   |   [SSD M.2]   Amazon.com: Western Digital 2TB WD_Black SN750 NVMe Internal Gaming SSD - Gen3 PCIe, M.2 2280, 3D NAND - WDS200T3X0C: Computers & Accessories   |   [MOTHERBOARD]   Amazon.com: ASUS ROG X570 Crosshair VIII Formula AM4 Zen 3 Ryzen 5000 & 3rd Gen Ryzen ATX Motherboard with PCIe 4.0, on-Board WiFi 6 (802.11Ax), 5 Gbps LAN: Electronics   |   [CASE]   Amazon.com: Asus ROG Strix Helios GX601 RGB Mid-Tower Computer Case for up to EATX Motherboards with USB 3.1 Front Panel, Smoked Tempered Glass, Brushed Aluminum and Steel Construction, and Four Case Fans, Black: Electronics   |   [POWER SUPPLY]   Amazon.com: ASUS Rog Thor 1200 Certified 1200W Fully-Modular RGB Power Supply with LiveDash Oled Panel: Electronics   |   [WATER COOLER]   Amazon.com: Thermaltake Pacific CL360 Max D5c Res/Pump 16.8 Million Color RGB (Alexa, Razer Chroma) Software Enabled Copper Radiator PETG Hard Tube Water Cooling Kit CL-W259-CU00SW-A: Electronics   |   [WATER COOLANT]   Amazon.com: EKWB EK-CryoFuel Premix PC Coolant, 1000mL, Blood Red: Computers & Accessories   |   [THERMAL COMPOUND]   Amazon.com: ARCTIC MX-4 - Thermal Compound Paste For Coolers | Heat Sink Paste | Composed of Carbon Micro-particles | Easy to Apply | High Durability - 4 Grams: Computers & Accessories   |   [RGB HUB]   Amazon.com: Corsair iCUE Commander PRO Smart RGB Lighting and Fan Speed Controller: Computers & Accessories   |   [RGB STRIPS]   Amazon.com: PC RGB LED Strip, Speclux Computer LED Strip Lights for Motherboard with 12V 4Pin RGB Header, PC Case DIY Lighting for ASUS Aura Sync, Gigabyte RGB Fusion, MSI Mystic Light, ASRock RGB, 4PCS SMD 5050: Home Improvement   |   [RGB FANS]Amazon.com: Corsair iCUE SP120 RGB Pro Performance 120mm Triple Fan Kit with Lighting Node Core: Computers & Accessories   |
Amazon descriptions are really hard to read. This would be much easier for everyone. It would also allow us to make changes without completely restarting your list.
https://pcpartpicker.com/list/
There's a spot there to grab a link and it'll show us an embedded list.
That is very overkill for a gaming build..
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
i know but will it work
It'll work. That case is by no means excellent. Especially at that price though.
Project Hot Box
Oppbevaring
53 minutes ago, Goatholomule said:
Games
Go to PCPartpicker and build it.
They are good at listing compatibility of parts and also give a wattage estimate.
https://ca.pcpartpicker.com/
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
  • 1 month later...
Project Hot Box
Oppbevaring
how did you get a threadripper pro, and why
Don’t take everything I say seriously
take it with a grain of s a l t
Country:
Fastest at what? Threadripper only makes sense for particular workloads that can fully utilize all those cores. It will actually end up being just equal or even slower than even something like 3600 in most games, which barely use 6 cores.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
No you're not.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
9 minutes ago, Chris Pratt said:
Fastest at what?
at capping to OP's friend, so he can stop being an insecure fuck
But in the case that OP actually does 8K video editing, simulations that cant be done on GPU and needs a lot of PCIE lanes, he couldve step down to a 3970x or 3960x as a lot of threadripper pros are really for prebuilts.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
How'd you get a Threadripper Pro anyway. They were commercially unavailable. Linus said too. Even if you got one it would be very hard to get it's supported motherboard as the Threadripper Pro is only coming in prebuilts so the motherboard would also be like that
If my answer is correct or is helpful please mark it as the solution. Quote me in your post to summon me. Beware that after summoning me ill never leave.
He didn't.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
Just now, Middcore said:
He didn't.
How do you know?
1 minute ago, Goatholomule said:
gaming
5950X will be better suited for gaming. Yes the 3990X has many cores, but many video games prefer a couple fast cores over tons of slow cores. Also, the price for a 3990X is really absurd to use just for gaming purposes.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
i didnt mean to
5950X is hands-down better.
Threadripper CPUs are better for things such as video editing that like more cores over higher clockspeeds.
EDIT:
Oops, posted on wrong thread!
Sorry about that mods 🙂
elephants
5 minutes ago, boggy77 said:
yeah threadripper is not optimised for gaming.
the 5950x is the best cpu at gaming, but it's also not aimed at gamers and it's a waste of money for gaming.
for purely gaming, the 5800x will give you 99% of the 5950x performance for half the price
or he could get the 5900x, just $100 more than the 5800x, and it'd be good for foward facing, the 5900x does have better value then the 5800x
my signiture was cool, but its a lie now
Watch videos on EACH and compare what you can I guess.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
It's crazy to think that AMD has a Ryzen that at MSRP is priced so similar to Threadripper is mind blowing. I love it!
For gaming and general use, 5950x is better.
I'm of the mindset for Threadripper and Intel's "XE" HEDT lines that if you need them, you know it.
Project Hot Box
Oppbevaring
Gaming only use up to 8 cores so far so adding more cores won't do you much, that's why we don't see much difference between a 5800x and 5950x.
the 3990x has no value for gaming, you will get better results with the 5950x
Unless you're doing rendering the 3990x doesn't make sense
