How should I set up my fans?
Unilision
Hi, I'm here to ask if anyone could possibly give me some advice on how to set up my fans inside my case between intake and exhaust.
I have a total of 9 fans; 240mm front which will be my AIO cooling doing intake, as for my bottom and top of the case are both 360mm, with bottom having about 10cm between the gpu, should I do the bottom intake and top exhaust? and I have 120mm back of the case which will be exhaust. Would this work or how should I do it? I've attached my build below
PCPartPicker Part List
CPU: Intel Core i5-10600K 4.1 GHz 6-Core Processor  (Purchased For $0.00)
CPU Cooler: NZXT Kraken X53 73.11 CFM Liquid CPU Cooler  ($148.75 @ Vuugo)
Motherboard: Asus ROG STRIX H470-I GAMING Mini ITX LGA1200 Motherboard  (Purchased For $0.00)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (Purchased For $0.00)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive  ($196.95 @ shopRBC)
Storage: Western Digital SN750 1 TB M.2-2280 NVME Solid State Drive  (Purchased For $0.00)
Video Card: Gigabyte GeForce RTX 3080 10 GB GAMING OC Video Card  (Purchased For $0.00)
Case: Lian Li O11 Dynamic Mini ATX Mid Tower Case  ($129.99 @ Canada Computers)
Power Supply: Corsair SF 750 W 80+ Platinum Certified Fully Modular SFX Power Supply  (Purchased For $0.00)
Case Fan: In Win Sirius Loop ASL 50 CFM 120 mm Fans 3-Pack
Monitor: Samsung C49RG9 49.0" 5120x1440 120 Hz Monitor  (Purchased For $0.00)
Total: $475.69
Generated by PCPartPicker 2021-04-19 10:48 EDT-0400
I7 4790K • Corsair H110 • MSI Z97 SLI Krait Edition • Kingston Fury Hyper X (White)(16GB)(1866Mhz) • Crucial MX 100 512 GB • Seagate Barracuda 1TB • Phantek Enthoo Pro • EVGA G2 750 Watt
Asus DRW Optical Drive • TP Link Wifi Adapter • Asus MX279H • CM Devastator Bundle (Blue) • Bitfenix Spectre Pro (White) • Windows 8.1
Galax Hall Of Fame 970
