Should I return my power supply?
Solved by emosun,
if you received a different product than what was pictured then you can return it regardless as it was misrepresented. You have plenty of documentation showing the products are different externally and internally to back up your claim.
TheNaitsyrk ·
Posted in Graphics Cards0 -
1
12345678 ·
Rummers ·
Posted in New Builds and Planning3 -
a7med ·
Posted in CPUs, Motherboards, and Memory1 -
7
1
moondogkill ·
Posted in Cooling2 -
1
snaphappy7530 ·
Posted in Troubleshooting4
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
