Search In
  • More options...
Find results that contain...
Find results in...
My GTX 1650 is making a grinding noise
So my GTX 1650 is making a weird grinding noise with its fans. I spinned the fans manually and the noise is still there but its really only hearable when the fan usage goes over 90%. I am pretty sure that my fans need to be lubricated but idk how to do it. If there is another proplem please tell me.
When does a GTX1650 Fan need over 90% outside of Small Form factor PCS.
How hot does it get right now?
Just use it at a lower fan speed.... or co sider RMA on the GPU. (Return it)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Overclock and i dont know if i can RMA it when i didnt build the pc and dont have the receipt
The way to lubricant a fan is to find the side with the sticker lift the sticker and add lube.  It doesn’t work very well quite often though and the sticker doesn’t always restick again which actually makes things worse rather than better. A 1650 may be safe to RMA in this environment I’m not sure.  There have been reports of companies simply keeping RMAed GPUs and issuing checks for them.  One possibility if you’ve got enough extra space is removing the shroud but not the cooler and zip Tying on case fans as replacements.  Pretty much always makes the thing thicker though which can cause problems depending on the situation.  It not infrequently lowers noise and improves cooling though.
Edited by Bombastinator
2 minutes ago, Bombastinator said:
The way to lubricant a fan is to find the side with the sticker lift the sticker and add lube.  It doesn’t work very well quite often though and the sticker doesn’t always restick again which actually makes things worse rather than better. A 1650 may be safe to RMA in this environment I’m not sure.  There have been reports of companies simply keeping RMAed GPUs and issuing checks for them.  One possibility if you’ve got enough extra space is removing the shroud but not the cooler and zip Turing on case fans as replacements.  Pretty much always makes the thing thicker though which can cause problems depending on the situation.  It not infrequently lowers noise and improves cooling though.
are there any fans you could recommend i am not too worried about my space
I don’t know brands and models anymore I’m afraid.  I can speak generally though. Depends on how the thing will be oriented when in place.  If it’s vertical (which would likely only happen if a machine is set flat on a desk with the motherboard down) you could get away with a sleeve bearing fan which are cheap.  More likely you will need a fan that can handle being horizontal.  So double ball or FDB or some other modified rifle bearing.  One easy way might be to pick a fan designed for AIOs as they have all the same needs.  Not sure how big you will need to go either as I’m not familiar with your card. Could be 80mm, 96mm, or 120mm.  I very much doubt 140mm
ok thank you so much
23 hours ago, idkandidc said:
Overclock
still that is a gtx 1650 that uses like 65w of power. how hot does it get? if it is under 87c it is fine!
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
