Ram Speed which is better!?
Solved by mariushm,
The SPD tab in CPU-Z will have a list of profiles stored inside the ram sticks. It should have one for 1600 Mhz (which is the 3200 Mhz preset, because real frequencies are half the advertised frequency)
Currently, it looks like you managed to make your memory run at 3200 Mhz (1597x2 = 3194 mhz) but your timings are a bit high. Try to get them down to 18-19 for the first 3, and something like 42 and 60-65 should be doable for the other 2 (but use the ones in the profile)
