beginners Camera suggestions for landscapes and beginners?
5 hours ago, TheInvisible_Dude said:Thanks a lot for breaking down the explanation!
This is why I wanted to ask directly. You included many details I wouldn’t find on other websites or Youtube—but that’s because it’s general information, ofc.
Also thank you for the link, knowing which online stores to check narrows it down a lot; Out of curiosity, it is a bad or good idea to buy used cameras, or it just depends from where do you get it? For instance, if you buy it from a person there mightn’t be guarantee and stuff like that. Meanwhile, perhaps buying from a store could be safer.
Just asking because I think all electronic devices can be tricky to buy, even more when prices are high.
Also thanks for the PS
To be honest, I never actually bought used. It could be a good idea probably from ebay, or someplace where they have buyer protection or something, Indians don't really use it, I'm not familiar with it. I think unless you're 100% sure of what you're gonna get, it's probably safer to buy new from a store. Also guarantee/warranty could be important, you're gonna be travelling with it, if it gets damaged, you could just use that service when you come back home. I really don't think I'm qualified to answer this, lol.
Also another thing, popped in my head while typing this. Since you mention you need your camera gear to be light, you could look into the micro four thirds systems from Panasonic or Olympus for that matter. Like the G85 which I previously mentioned, not only would these camera be lighter, but also the lenses are lighter and often smaller, I forget the exact details, but prolly because it has something to do with having less flange distance, i.e shorter distance between the lens mount and the sensor. So that could be something.
Also thoroughly check the lens ecosystem of each and every camera, as you'd buying into the ecosystem.
