How do you learn hard line custom water cooling installation?
Solved by SorryBella,
3 minutes ago, Vilacom said:Is there a way to practice at all?
Yes, learn how to properly use hardline kits. Buy one and a few hardline tubes (also heat gun, most hardline kit doesnt come with one and propane is very inconsistent) and learn how to bend without snapping or kinking the tube. Those youtube videos youve watched probably already gives you a good idea on how.
But in my opinion, for a first watercool build, always go soft tube. Its easy, less risk of pressure crack, and most watercool kits (if you wanna go with those) already come with them.
