Im dumb and i need help
Go6ko
Sooo im new to building pcs and i found a 3060 that was cheaper than a 1660, and the 3060 was quite small compared to other 3060’s and i just need to know which one is better, im 99,99% sure the 3060 is better but here are the exact names of them
MSI GeForce GTX 1660 SUPER GAMING X - 6GB GDDR6 RAM
ASUS GeForce RTX 3060 DUAL 12GB GDDR6 RAM
 The 1660S Gaming X is a higher-end AIB 1660s, if the market was normal both of those cards would be around the same price. The thing is, the market isn't normal, the market is shot to hell. Can you provide the links, or the prices and currency? 9/10 it's either a scam or you're looking at paying 2-3x the MSRP of the cards.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
The 3060 is $435
The 1660 is $450
Its not a scam, its a store in my local area
2 minutes ago, Go6ko said:
The 3060 is $435
The 1660 is $450
USD? That 1660 is pretty overpriced if so. And the 3060 is in stock? What about the 3060ti?
I found a ASUS GeForce RTX 3060 Ti DUAL - 8GB GDDR6 RAM for $530
Are they in stock though? That's the question. If you can afford it i'd probably go for the 3060ti.
Yeah they are in stock, but what about the difference in the 4 gddr6 ram? Or does that not matter
12gb on the 3060, yeah that's pretty useless. It's basically just for show.
Ok thanks for the help. im probably gonna get the 3060ti.
