3060 mobile or 2070 super max-q?
Jaed
I'm buying a new laptop but i'm very confused on which gpu I should get. Should I go with a 3060 mobile or a 2070 super max-q? I'm mostly gonna do 1080p gaming
it depends on what is the power limit of the 3060 in the laptop you're looking at. The performance can vary quite a bit depending on how much power they're giving it.
But I would say probably the 2070S Max-Q. Performance will be better than a low-power 3060 and about the same as a high-power 3060, and the 2070S has more VRAM. But there's not much difference between the two unless the 3060 has a really low power limit like 65W.
Powerspec 1530 (Clevo PB50DF2) ~ i7 10875H ~ RTX 2070 Super 115W ~ 32GB DDR4 ~ 2x 1TB NVMe ~ 2TB 5400RPM ~ 1080P 240hz matte IPS
Gigabyte G1 GA-970-SLI ~ FX 8320 @ 3.3Ghz, 1212mV ~ 16GB DDR3 ~ Radeon 570 4GB ~ 512GB NVMe ~ 2x 1TB HGST 7200RPM
Xtras ~ Dell 22" 1680x1050 matte IPS monitor ~ Logi M705 mouse ~ PowerA Fusion Pro Xbox One controller ~ Sony XB950N1 headphones ~ Epson V700 film scanner
Streaming Setup ~ OBS Studio with AMF encoding ~ iVCam bridged to LG G6 ~ Focusrite Scarlett Solo interface ~ TONOR condenser cardioid mic
