Fresh build will not start :(
A6di
Hi guys.
I need help - I have done everything from: https://linustechtips.com/topic/42440-readme-how-to-respond-to-a-no-post-or-no-power-up-situation/
I'm currently building a pc for the first time.
Specs:
Intel i5 11600K
ROG STRIX Z490-F GAMING
GTX 1070 Ti 8GB (waiting for 3060 ti or a 3070)
Corsair Vengeance LPX DDR4-3600 C18 BK DC - 16GB
Samsung 970 EVO SSD M.2 2280 - 1TB
GIGABYTE P850GM- 850 Watt - 120 mm
NZXT Kraken X63 CPU
NZXT case H510i
I have highlighted the places, I have used on the mobo.
Earlier today it wouldn't start, but after troubleshooting and almost starting frem bottom, i solved the issue.
Then I tried to BIOS Flashback from USB, as the MOBO is not compliant with lake cpu 11-gen.
After it was completed, the PC started and I got POST for the first time: "updating BIOS, do not restart" - it restarted after 20 sec itself > then "ME updating, do not restart" it restarted itself again.
Now I cannot start the pc. The rpg light from MOBO is on, and I can see from GPU it gets power (a little light is on).
The Q LEDS don't show which key components to check, no light from them.
Do you have any recommendations/solutions to try?
Have a great day.
You could try clearing or CMOS or since most boards don’t have to boot in order to use the BIOS flashback button you could try that again.
Already tried that couple of times and reinstall everything + bio update.
Also took the Cmos power out for like 10 mins 😕
try flashing again, make sure you follow these directions
https://www.asus.com/support/FAQ/1038568/
and use this bios
https://rog.asus.com/motherboards/rog-strix/rog-strix-z490-f-gaming-model/helpdesk_bios
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
16 minutes ago, Letgomyleghoe said:
Just done that again, nothing happens, when I push the power button.
Not fans starts etc.
Only the light from motherboad and GPU is on.
No Q leds, so I can see what to look after 😕
your display cable is plugged into the gpu?
did you rename the file with the tool and move it to the root directory of the drive? have you checked all your connections?
AMD blackout rig
I would make sure there weren't any BIOS updates you needed to do before the most recent one. Sometimes you will have to install a few different ones to get to the most recent one.  Otherwise this is and odd situation. I've had boards not post before because of multiple reasons but I've never had one that posted once and then not again afterwards without changing hardware.
Nothing happen..
I have now tried to take out everything from the case.
Tried to start only motherboard and fans. The cables that was connected was:
Power 24-pin and 12-pin
System front panal (power)
2 fans (from the case)
Nothing happen. even the power supply fan was of.
