Fans controlled by CPU and GPU?
Solved by cottontails2,
Currently i have 8 Noctua NF12 fans on a PWM hub and set up in Fan Expert 4 to go by CPU temp, but ever since i upgraded to a higher resolution my GPU temps go up to 80C while my CPU is sitting at 40C, is there an option in the bios or any kind of software that would go off both GPU and CPU temps?
Edit: going to give Argus Monitor a try
Update: Argus works amazingly and solved my problem, a mod can delete this
Share
Followers
1
