Search In
  • More options...
Find results that contain...
Find results in...
No signal on monitor after swapping cpu
So I decided to change my cpu from a Ryzen 3 1200 to a Ryzen 5 2600 and when I tried to boot my computer it showed no signal on my monitor.The lights and fans turned on but there is no signal on the monitor.But here's the thing when I put my old cpu back in the socket it didn't show signal like the when I had the new cpu in.So I kept turning it on and off until it turned on and let me log in but then turned off immediately after.
Motherboard:A320M HDV
did you update the bios
NOT A PROFESSIONAL, just a tech nerd. I am a human and can be incorrect. dont forget to quote me and put full specs in troubleshooting posts
Main Setup (all prices in USD since its pretty widespread and well known)    PCPartPicker List Link
AMD Ryzen 5 1400 CPU - $85, Deepcool Gammaxx 400 V2 Blue CPU Cooler - $25, Biostar B450MH AM4 Motherboard - $65, Timetec 16GB (2x8) 3200MHz CL16 DDR4 RAM - $60, Adata SU650 240GB M.2 SSD - $30, WD Caviar Blue 250GB 7200RPM HDD - $20, Seagate Barracuda  320GB 7200RPM HDD - $20, MSI Aero Nvidia GTX 1060 3GB GPU - $200, Cougar MG130G Micro-ATX Case - $50, Aresgame AGK750 Fully Modular 80+ Gold PSU - $90, HP 22EB 21.5" 1080P 60Hz Monitor - $100, Samsung 21.5" 2S22E450D 1080P 60Hz Monitor - $90, Sceptre E205-W 19.5" 1600-3R 900P 75Hz Monitor - $70, GK73X Hot-Swappable Mechanical Keyboard (Gateron Red Switches) - $70, HK Gaming Dye Sub Chalk Keycaps - $40, Steelseries Rival 3 Mouse - $30, Redragon Mouse Pad - Came with bundle, Random XXL Amazon Mouse Pad - $10, Widesen USB Condenser Mic - $20, Gertisan Mic Arm - $12 (adapter needed, + $4), OneOdio Over Ear Headphones - $33, Cooler Master SickleFlow 120MM Blue Fan - $10, Iceberg Thermal IceGALE 140MM Teal Fan 2 Pack - $45, Cougar 120MM Case Fan - Included with MG 130G
Rack Project (Build log link)
Rack Project PC (1)
Intel Core i5-2400 CPU - $25, Vetroo L5 CPU Cooler - $30, Dell Optiplex 390 LGA 1155 Motherboard - $15, G.Skill Ripjaws 16GB (2x8) 1866MHz CL10 DDR3 RAM  - $50, Leven 120GB 2.5" SSD - $22, MSI Aero Nvidia GTX 1050 TI 4GB - $150, Segotep GP 600W Non-Modular 80+ Gold PSU - $52, Tecware Spectre RGB Pro Mechanical Keyboard (Outemu Brown Switches) - $70, Pictek T16 Mouse - $23
Rack Project PC (2)
Intel Core i5-2400 CPU - $25, Enermax ETS-N31 CPU Cooler - $25, Dell Optiplex 390 LGA 1155 Motherboard - $15, 8GB (2x4) Hynix 1600MHz CL11 DDR3 RAM - $30, Leven 120GB 2.5" SSD - $22, Intel HD 2000 Graphics - Integrated into CPU, Cooler Master MasterWatt Lite 600W Non-Modular 80+ PSU - $50, HP Office Keyboard - $5, Havit Mouse - $10
 "I had the parts lying around" PC
AMD A8-4555M CPU, "Stock" Cooler, Coinmine ITX Motherboard - ($Total of 3=$35), 8GB (2x4) Hynix 1333MHz CLsomething DDR3 SODIMM RAM - $22, HP 120GB 2.5" SSD - $203, AMD Radeon 7600G Graphics - Integrated into CPU, EVGA N1 400W Non-Modular PSU - $40, InWin 303 (Yes, I know its a ridiculously expensive and high end case for this type of build. I got one for free and had it lying around.) - $90, Thermaltake Riing 120MM Blue Fan (x3) - $17 Each, Cooler Master 120MM Case Fan - $10, Redragon S107 Keyboard + Mouse + Mouse Pad - $37
Other parts I have lying around
3 Dell Optiplex Stock Coolers (1 broken), Cooler Master T2 Cooler, Intel Stock Cooler, Replace Power 420W PSU, Broken FX-8350, Broken Asrock 970 Motherboard, 2x4GB DDR3 RAM 1333MHz, a Dell Office KB, a bunch of office mice
Dell Inspiron 15-3575 Laptop
Intel Celeron N4000 CPU, 4GB RAM, Windows 10 Home Activated 64 Bit, 500GB HDD, Intel UHD 600 Graphics
Gateway Vintage Laptop from 2006 probably
Intel Core 2 Duo T5500, 3GB RAM, Windows Vista Home Premium Activated 32 Bit, 250GB HDD, Intel 965 Graphics
I can't update the bios.I have no access to my computer settings but that still would not explain why my computer won't boot even with the old cpu in the socket.
