Search In
  • More options...
Find results that contain...
Find results in...
3070FE thermal pad replacement advice.
Hi, i have a 3070FE and am looking to upgrade the thermalpads on the vram which connects to my backplate as it gets very hot, looking some advice on which thermal pads to use
