Should I turn on freesync with a Nvidia card
Solved by Moonzy,
4 minutes ago, SquiddyButler said:I don't know exactly what freesync does
this, except no special module
end result is about the same
5 minutes ago, SquiddyButler said:should I turn it on?
depends if it's G-sync compatible, and if it's giving you any issues when it's on even if it's certified
