The problem I am having with the RX570
Ag047
I was using my GPU with a converter for 2 years but 4 days ago my converter just burned. I put a picture of it here and I just bought another one. I used it since today. I smelled burning like before while playing CS:GO. It was the same smell and I just turned off my PC. Then I turned on it again, it's working. I will upgrade my PC soon but I'm worried about my new PC parts. Can someone help me find where the problem is?
Immediately stop using a component that burned, for your own safety and at least for the safety of your computer.
Too much current through a rather crappy looking cable. If your power supply does not have PCIe power connectors, chances are it is not capable of properly powering a GPU.
Primary PC:
The fact that you say that youve been using it for 2 years gives the impression that it might have been physical damage to the cable
